RCU Forums - View Single Post - What is the disadvantage of Y connecting 2 batteries into the receiver?
Old 10-03-2008 | 09:36 AM
Rodney
Default RE: What is the disadvantage of Y connecting 2 batteries into the receiver?
Another possible problem with using the Y instead of two seperate paths is that many Y's are not of sufficient gage wire or could have a bad solder joint that will cause excessive voltage drop under load. The quality of the switch is also a possible problem here as some switches do not pass high currents without a significant voltage drop. Two switches, two wire paths give 1/2 the impedance to current flow.
