RCU Forums - View Single Post - Loose Robart hinge point (after 3 years)
Old 10-04-2008 | 06:21 PM
Steve's Avatar
Steve
My Feedback: (54)
Default RE: Loose Robart hinge point (after 3 years)
If you choose to repace all the hinges, I've found that cutting the nuckle and removing the surface, then use a soldering iron to melt out the old hinge leavse a perfect hole. Then use a 3/16 drill bit to clean up the hole and re-hinge.
