RCU Forums - View Single Post - Thunder Tiger 54 issue
Old 10-05-2008 | 07:55 AM
Charley
Default RE: Thunder Tiger 54 issue
Could it be that your clunk is too close to the rear of the tank? If the abrupt pull-up forces the clunk up against the rear wall of the tank it could cut off the fuel flow momentarily. Sounds like the carb is near the center of the tank, depending on the tank dimensions.
BTW, what's the RPM with that 11x7 prop?
CR
