RCU Forums - View Single Post - Loose Robart hinge point (after 3 years)
Old 10-05-2008 | 10:06 AM
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: Loose Robart hinge point (after 3 years)
I could pin it but the hinge point is a little small to nail blind. Also there's so much slop in the hinge hole that it needs to be filled up. The urathane glue is looking like the best solution. I'll have to get some water in there and then the urathane glue, then keep it from oozing out all over the wrong places (especially the hingle jont). I'll probably do multiple holes on the top and bottom. I'll probably put a little drop of oil on the hinge joint to keep it from sticking when the glue is all set up and dry.
