RCU Forums - View Single Post - Is it possible to put a .18TZ in this????
Old 10-05-2008 | 10:30 AM
motionmachine
Default RE: Is it possible to put a .18TZ in this????
ORIGINAL: dragon2k2
is there any adabter or anything i could make it work cause holes r about a quarter of an inch bigger in the .26. but they are the same distance from top to bottom
Thats like sticking a 4 cylinder car engine into a one ton truck chassis... Sure its "possible" but its certainly not practical.
Even if you managed to fit the .18 TZ on an 1/8th scale MBX R-2 chassis, IMO you'd be quickly disappointed, specially with the bottom end accelleration.
At minimum, you want a .21 CI motor for that 1/8th scale application.
