RCU Forums - View Single Post - Flywheel question
Old 10-05-2008 | 06:39 PM
125cchyperman
Default RE: Flywheel question
uhmmm depending on how much lighter your flywheel is there may not be much of a difference, but if the difference in weight is a lot then you may experience your engine not idling right or not even being able to stay running, if to much weight is taken off..... Now with just 1 or 2 mm difference between the two I dont think you will have a problem with it......
