I'd use that sprial wrap Milton gave you for your spark plug wire. Also I'd put some little zip ties on all your tygon connections
The model is stripped down waiting for the new exhaust, so much of the cables and pipes are just sitting there. I usually use a wire clip to hold the fuel pipe on, but I pushed the pipe back on to stop the fuel system drying out.
The plug lead is usually cable tied to the stand offs. Never thought of using the Spiral wrap for that, will give it a try. Thanks for the suggestion.
Peter
