RCU Forums - View Single Post - electric starter
Old 10-06-2008 | 11:59 AM
opjose's Avatar
opjose
Default RE: electric starter
ORIGINAL: Springer
Can you tell me more about the packs you use? Are they sub-c?
Yup I pretty much did what John said above.
The only difference is I used two "Wolfpack" 3800mAh 7.4v packs from Tower wired in series to produce 14.8 volts.
I cut the existing cable from the starter and wired up two Tamaya style connectors for the batteries.
I charge each battery separately on my charger... so I charge the packs up in 2 hours at 1C.
On a typical weekend of flying I use up about 1000 mA on each pack ( or less! ) and that's over 20+ starts, including hard starts, larger planes, etc.
In other words I could theoretically go 1 month between charges if I wanted to... I tend to charge the packs every 2 weeks though.
I had previously purchased the Hobbico 12v battery and container sold by Tower. But I found that the battery would barely last me a season, and the starter was anemic with the battery sold by Tower.
After starting a larger plane, after borrowing a starter from someone at the field, who had done what John is suggesting, I decided to do likewise... there is NO going back now! It's a huge difference..
