ORIGINAL: Springer
I have the battery pack from Tower and I am very unhappy with the performance. I thought You had found something that would fit inside the case. It would be an easy solution with minimal fabrication for me since the case is already attached. If that is not a good way to go I will do what you and John did.
Yes I fit TWO 3800 "Wolfpacks" within the Hobbico case.
I had to cut away part of the flashing, but they fit just fine once done.
