RCU Forums - View Single Post - Cooling
Thread: Cooling
Old 10-07-2008 | 08:21 AM
cyclops2's Avatar
cyclops2
Default RE: Cooling
I use the bottom of the engine compartment for a LOT of exhaust holes. I happen to mount most motors upside down for that reason. The small GWS Corsair has 6 small 1/2" holes drilled in a downward and backward direction. 6 small holes DO NOT weaken a structure as much as 1 big hole of the same area.
If you use offset gearboxes you can REALLY get the motor low & directly into the airflow.
Air flows from the inlet straight to the outlet. Even if a motor is directly in the way.
Think like that and you should come out fine.
