Ammonia might alter or interfere with the cure of the CA you planned to use to adhere the line
components in the cut outs. While ammonia will do the trick for relaxing cellulose fibers it just
might eliminate the bond of the CA as well. Then again you might be launched into a 60's era
trip of sorts...one from which you might not return...[sm=bananahead.gif]
Just a thought...
