RCU Forums - View Single Post - Loose Robart hinge point (after 3 years)
Old 10-08-2008 | 11:29 AM
JoeAirPort's Avatar
JoeAirPort
My Feedback: (41)
Default RE: Loose Robart hinge point (after 3 years)
Guess what I discovered upon closer inspection last night? The hinge point hole was not drilled on the hard point....that or the hard point was in the wrong position on the left wing half. Either way my hinge point was not going into hard the wood block provided. I found this out by looking at the wing with a bright light behind it. The block is clearly an inch or two to the outside of the wing. I looked at the rest of them and some are very close to missing the hard points....but there are in them.
I did not drill these holes, they came pre-drilled from the ARF MFG.
There isn't much space to get a needle in the hinge. I tried to fish some very small music wire and it had to be jammed in to even go in a little bit. Drill baby drill !!
