RE: Loose Robart hinge point (after 3 years)
Hey Joe- If you are going to inject the epoxy with a needle, you could mix in some micro balloons. If you find that the mixture is too think for the needle, make a few passes over the syringe with your heat gun and it'll turn it into water and let if flow nicely. I'd use at least 15 or 30 minute epoxy, and when it sets up, will be just like you want.
