ORIGINAL: DonH21
Oh, Yes I did!!
19oz. with out the battery. 10x4.7 slow apc prop hovers better then I usually do
. Knife edge tucks a little to the landing gear. I Landed in some ruff turbulence, the grass grabbed the left wheel and spun it around over 90 degrees and dragged the right wing tip, just a little scuffed up.
Same thing happened with my Mini Funtana 2 years ago and shattered the stringers on the fuse, very fragile. I ended up sheeting the sides of the fuse with 1/16 in balas. I'm just comparing the strength of the AirfoilZ to the Funtana weight about the same, and the Airfoilz is larger as well.
I'm very happy with it.
Don
Great to hear!! Trying moving the CG back a hair...once you have the CG dialed in the Extra will Knife edge with very little input!
