ORIGINAL: jib
I've been reading a lot, but still cannot tell for sure if I can use my current wall wart 4.8v NiCad charger on the NiMH, as long as I give the larger pack sufficient time to recharge? I understand V=iR and C, C/10, etc.
Yes, I know a NiMH specific charger would be better, but why spend the $40-$100, if I don't have to. Don't hesistate to let me know if I am being short sighted.
Jack
You can use your 4.8 NiCad charger for your 4 cell 4.8 volt NiMH batteries even if much bigger capacity. It will take longer to charge them. If bigger than @ 2000 Mah I'd recommend a better charger also. IF you go to 5 cells (6 volts) you MUST get a new charger, no option.
