ORIGINAL: Sparkey Hello
I have 2 servos operating the elevator on my Big Stick but they are connected to a y harness to make one plug into the reciever
I have servo on each side of fuselage and each one separately moves one side of the elevator Problem when you look down from the top one servo arm is facing up and the other side facing down so what happens is when elevator is applied the they are doing the job but moving in opisite directions. What can be done other than running two receivers? As always Thanks
SPARKEY
You do not mention which Transmitter and receiver and how many channels are available.
For electronic TX & RX set-up,
1.
Hitec Optic 6 - Tutorial (good to learn mixing and other computer functions irrespective of model)
2. Use a "Y" lead with a reversing circuit in one leg or a Vtail mixer plugged into RX elevator channel only (aileron lead plug tied back).
For manual installation refer to:
Mounting Dual Servos for Split Elevators
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
