RCU Forums - View Single Post - CMpro Giles CG
Old 10-09-2008 | 12:23 AM
TZflyer
Default RE: CMpro Giles CG
ORIGINAL: da Rock
If noone answers with the numbers from the CMPro manual, there is a simple and very reliable alternative. Take a yardstick and about 5 minutes of your time and measure the model you have sitting before you. Plug the numbers into this application http://www.geistware.com/rcmodeling/cg_super_calc.htm give it 20% for the Static Margin and click the button. Record the CG location. Then change the 20% to a 5% and click again. Record that second CG and you've got a safe, reliable, usable range for the CG that will work for your model.
Thanks da Rock, that's a very useful calculator!
The plane isn't assembled yet, we have another few projects on the go first but if no one comes to the rescue we will definitely use it.
