RCU Forums - View Single Post - poulan wildthing 40cc
Old 10-09-2008 | 10:43 PM
av8tor1977's Avatar
av8tor1977
Default RE: poulan wildthing 40cc
It's a good engine. The 36 to 42cc Poulans are basically identical and weigh the same, so I would buy the 42cc. Do a search here in the forum for Poulan 42cc and you should come up with quite a bit of info.
The Poulan 46cc is a different design, and I'm told it is a good bit lighter. The only problem with the 46cc Poulan is that it has a rubber boot mounted carburetor. You have to fabricate a manifold for it to work in an airplane, but a lot of guys use them. Check with CH Ignitions, as they used to have conversion parts for the Poulans. www.ch-ignitions.com
Just remember, if the weight and the dollars are going to be similar, you might as well get the biggest engine.
AV8TOR
