RCU Forums - View Single Post - P60 ECU V5.0 UNKNOWN ERROR
Old 10-10-2008 | 05:02 PM
mr_matt's Avatar
mr_matt
My Feedback: (10)
Default RE: P60 ECU V5.0 UNKNOWN ERROR
ORIGINAL: GIOMBO
Hi Mr.Matt thanks a lot for your instructions, thats all I need
another things........... If I use a single channel for run the engine.........the aux cable need to fit into receiver or I can leave its disconnected and blocked????[][]
Hello,
The short answer is "yes", if you run single channel, then you can leave the "Aux" line to the ECU disconnected.
The longer answer is, I would hook up the "Aux" line AFTER you have performed the "Learn RC" step. You will STILL be in single channel mode, but the ECU will now have 2 sources of power (from both the "Throttle" and the "Aux" line) even though the ECU is only taking commands from the "Throttle" line signal.
Hope this helps,
