You need to reset the sensor position. With the magnet 30º BTDC as you have, the sensor needs to be right in front of the camshaft, on top of the front bearing housing.
Considering the first photos you posted, your ignition is retarded around 40º! No wonder the engine lacks power.
Reset the sensor position and run that baby once again
