RE: Tamiya TB-01 Resource Thread!
Stock gearing -> 16T pinion and 61T spur.. which is very undergeared for a silvercan.. so I am not sure why Tamiya chose this as the stock setup. (Consider this is the absolutely highest gearing ratio that can be achieved with this kit. It comes w/ 58T and 55T spurs as well, and those will require even bigger pinion for proper engagement.
Hmm... odd, isn't it?!
Doesn't matter for me, since I will be using the 5700kv motor, but just thinking that it is low for a stock silvercan...
Don't worry about the mesh -> when installed onto the chassis, the center driveshaft will be push toward the motor..
