RCU Forums - View Single Post - Multiplex Easy Star, construction, flight report
Old 10-10-2008 | 11:43 PM
  #122
Dr Kiwi
Default RE: Multiplex Easy Star, construction, flight report
Tony,
If one uses a more powerful brushless motor, the tendency to climb under power will be exacerbated, so one would need to tilt the motor down at the rear (prop end) so as to push the nose of the plane downward. Remember that the motor is behind the CG, so you effectively are seeing rotation around that axis.
