ORIGINAL: sanman55
One other question, Is the battery getting very hot? I know on my starmax gripen I had to add some air holes in the fus to cool it down.
Thanks [8D] sanford
Taking out the nose servo could solve your CG issue (you did say you liked it tailheavy). Its a little tricky getting in there but if you take out the battery placement bracket where the lypo sits, you should be fine. In regards to your lypo, if it gets real hot...you might want to run! I know what you ment by that. The battery does get warm but dont worry the batterty cover is a plastic grid which provides plenty of air. If you have not seen it, here is the review from nitroplanes.
http://www.youtube.com/watch?v=kH2o8SsMTbY
Happy soaring
