RE: Multiplex Easy Star, construction, flight report
Well Tony,
I can see you'll need to try it with the stock angle and find out whether it needs adjustment... a washer at a time.... up or down!
I would imagine that the position of the CG might affect things - if you like a forward CG then it might dive under power, but if you prefer a CG fractionally rearward, then it may climb with power on.
