Factors that affect Torque Roll Rate?
Why would a heavier prop help? The only thing that could help is the way the flier puts his plane and the diameter of the prop. The larger the diameter, the better the aircraft will turn and remain controllable because of more air over surfaces.
In fact, a heavier prop should be harder to fly with because the engine will spool up slower and small, fast corrections become harder to perform. An instant blast is what you should want.
