RE: VQ Me 109 E Build Thread
Hello Raven,
I have the newer 109 version with 2 aileron servos plus I run them on 6V. But you should be fine with the standard servo on 4.8V. As is stated before, the retracts in the box are a rather wobbely solution. I replaced them with Robart air retracts after 2nd flight. No regrets. Never installed the wheel pans due to sidewinds. Engine: A .61 is fine. If you don't like to butcher the cowling for the 2-stroke then go ahead and use your 4-stroke. Just stick them in there upside down and put a larger tank in. Don't get shy over engine power. This bird likes the additional nose weight.
