RCU Forums - View Single Post - another spektrum bind problem
Old 10-11-2008 | 11:12 PM
Ed
Default RE: another spektrum bind problem
You are probably using a switch that has only the two battery wires. The supplied Spektrum switch has 3 wires. You need a 3 wire switch, the third wire being the bind signal that your bind plug mates with.
Or ............... plug your 2 wire switch and batteries into an Aux channel. Then plug a short servo extention into the normal Bat / Bind port. The servo extention will have 3 wires. Now you can use your bind plug into the servo extention, and go from there.
... zak
