RCU Forums - View Single Post - Need help with YS-45
Old 10-12-2008 | 06:53 PM
dmccormick001's Avatar
dmccormick001
Default RE: Need help with YS-45
I don't think a leaky rear crankcase cover gasket would cause an engine to run rich, would it? Wouldn't that make it run lean?
I'd take a look at the ring in the engine that won't run right. Sometimes when a motor hasn't been run in a while the ring can stick and cause problems.
Also, if the engine stopped the last time it ran with a valve spring compressed, and it has sat for that long time without being rotated, the spring may have lost a lot of it's tension, and that could cause it to miss and run rough. Just a thought.
David
