RCU Forums - View Single Post - HOB Decathlon build
Old 10-12-2008 | 10:16 PM
  #44
kargo
Default RE: HOB Decathlon build
oops, that would be that new math. I agree completely; 11.1x19 = 210.9 then divided by 2 for 2lbs = 105.45watts per lb. Using the rule of thumb I've seen here and elsewhere that would be good aerobatic performance. Thanks for the correction and the advice.
Does it tip stall easily when its slow? Or do you get into that trouble when your stalling intentionally? Does it not like to recover from a spin?
I've got 2 3/4 foam wheels on it so we'll see what happens... maybe I should put it on skis
