RE: WACO YMF
Jim,
Can you adjust the incidence of yout horizontal stab? If not, you might want to fine tune the wing incidence. Try making the wing incidence 1/2 degree more toward the negative. How about your engine thrust line? Does this trim problem occur at all throttle settings, or only at high throttle, or low?
Bill, AMA 4720
WACO Brotherhood #1
