RCU Forums - View Single Post - Where should you be hovering?
Old 10-13-2008 | 11:42 PM
rzarikian
Default Where should you be hovering?
Ok I'm pretty confused with this: after watching finless bob's vids on setup and adjusting my 450 I now hover when the stick is at one line past the middle mark (the little guide lines on the side of he stick) with 5º of pitch and about 79% power, but the thing is I've also read and I've been told that you should be hovering at half stick with 5º of pitch with 65%. Now isn't the pitch supposed to be at 0º when you're at half stick? and if not then how do you set up the pitch curve so the heli doesn't jump when you switch to idle up? What is the correct way to set it up.
Thanks!
