RCU Forums - View Single Post - st 2500 backplate
Old 10-14-2008 | 09:25 AM
Bax
Default RE: st 2500 backplate
If the bolt holes for the rear cover fit the bolt holes in the case, then you have the correct rear cover. SuperTigre only made one kind of rear cover for the S-2000/2500 egnines. You may need to check to be sure the crank shaft is fully-seated in the bearings, or also that the rear bearing is fully-seated in the front case.
