RE: SETUP QUESTION
You can do either. The advantage of half stick is the collective is less sensitive. With 3/4 stick hover in normal mode the collective stick is still pretty sensitive but the disadvantage is the heli drops when you hit idle up if you dont do it on a climb out. I hover 3/4 stick all helis (even scale) and all flight modes, that way my helis all feel about the same in any mode.
