RCU Forums - View Single Post - Trex 450SA flybar setup question
Old 10-14-2008 | 06:56 PM
ace22459
Default RE: Trex 450SA flybar setup question
If you have the old flybar out and the new one in, make sure you have the same amount of flybar extending on each side of the flybar cage. I use digital calipers to measure all critical demensions. Don't have an exact measurment, you just kinda center it and carefully slide it to one side or the other untill it measures the same on both sides. Then put the flybar weights on and get them all the way out on the rod just before where the threads start. You can measure again to make sure the weights are the same distance out. Make sure all the set screws have locktite and are tight. Then just screw the paddles back on untill they are just touching the weights and they are level with the flybar cage. Eye balling is good enough and is how everyone does it. If you don't already know about Finless Bob and his build videos on the HeliFreak website, do yourself a favor and go check them out. There are complete build vids on the T-Rex SE which is exactly the same as the SA except the SE uses more carbon fiber and CNC parts.
