RE: Craftsman 32cc Weedeater
ok, finally grabbed my camera from upstairs...
this is just the engine with my prop hub on and the prop, the hub is just a simple spacer that looks like a prop hub, if this is my final setup I'll probably put some loctite on the taper and mayabe some on the hub or shaft to keep things from working loose, or I might put a roll pin between the hub and flywheel to keep things from rotating... for a prop washer I might make one out of aluminum, or I might just use a fender washer... maybe I can find the washer that came on the thing, if not, they're easy enough to find at work...
