RE: Balancing Waco bipe
From the leading edge of both wings at the fuse (guess on the upper wing were the fuse would be) 1/3 back...make a dot, one dot on the top of each wing..now connect the 2 dots with an imaginary line....your CG starting point will be in the middle of the fuselage on that imaginary line
