RCU Forums - View Single Post - 50cc Sukhette Build Thread, now in progress!!
Old 10-15-2008 | 01:03 PM
  #1357
rctom's Avatar
rctom
Default RE: 50cc Sukhette Build Thread, now in progress!!
ORIGINAL: Kenrico
Tom, again I have another question, I hope I'm not anoying you. what Safe distance would you recomend putting the MPI Regs. and Batts from the Receiver ? the Rx I'm running is the AR7000 with the DX7.
Thank you Again Tom.
The MPI regulators are kind of wimpy. I wouldn't use them if I had a choice, but if you are using 2 on a 50cc plane it should be OK. Keep in mind that low voltage on the AR7000 or any Spektrum receiver is to be avoided at all costs.
The regulators only have a short lead on them, that should go directl;y into the receiver. Any extension will introduce resistance and should be avoided.
TF
