RCU Forums - View Single Post - Best Performance 2-stroke For .60 Plane
Old 10-15-2008 | 09:15 PM
RACE 66
Default RE: Best Performance 2-stroke For .60 Plane
Ok ! I'll bite the hook. Yeah, Iam "old school" bought a Webra Speed RE with adjustable mixture on carb. ran a OPS pipe on FAI fuel. Hauled a scratched Deception through the maneuvers.
Performed well for the pattern we flew then. Very reliable easy start ie: spinner start, good power, wouldn't "sag" in maneuvers, powered through them well.
Yes, it is "pickled" for now, The "scratched" Deception at that time, was contest balsa, with 3/4 oz cloth and polyester resin and lots of sanding, KRAFT multi cons retracts, with the hot set up of using "Imron" by Dupont, bullet proof paint, BUT, you need to use a seperate breathing air source for your body. Memory recalls that it weighed around 11lbs. ! GULP ! Getting my new shop together, heat and all and then I am going to "scratch" another Deception to my own specs and throw in the Webra. Sweeeeeet Engine. Mike
