RE: Sig Rascal 110
king arthur
i did not beef up the strut area, although that is a good thought. the only thing i done was at the trailing edge of the wing in the center section on the fuse. i installed a balsa spacer there so when you tighten up the nylon wing bolts, it does not put a lot of pressure on the wing joint. i cant take a pic at the moment, older son went on a trip today and took the camera.........sorry. i will get something posted when he gets back in town.
thanks
Eric
