ORIGINAL: chuck l
Or may be the full wide open throttle is needed for obtaining full power in the air where the rpm's may be higher than those seen on the ground????
Probably.
The linkage method I described allows greater resolution at lower throttle settings before any curves are set with tranny computer. The way we did it in the old days.
