RCU Forums - View Single Post - Gas Engine Throttle Linkage Setup
Old 10-15-2008 | 11:13 PM
altavillan
Default RE: Gas Engine Throttle Linkage Setup
Once the throttle plate opens enough to equal the venturi size no further power will result from opening it further. A slight lean to the throttle plate helps turbulate and mix the fuel air mix also. As well as draw fuel from the jets with more effect. Vertical is not really an option. Power should start to decrease at vertical because fuel draw has started to drop. And a lean run condition will develope.
