RE: Prop and Spinner
I had a si,ilar issue...actually sounds exactly the same. Take a look at the back of the back plate where it sits on the propdriver. The hole in my back plate was smaller than the outside diameter of the propdriver. I ended up filing a small (even) amount of material off the propdriver so it slid into the backplate all teh way. Didn't have a problem after that. Good luck.
