6AXS Elevon problems
I am trying to program elevons on an Outlaw using the 6AXS. I've programed elevons before but I am having a problem that I can't figure out.
I have everything mechanically setup as close as possible to get the 1 1/4" throws that I need. I get 1 1/4" when I use up or down elevator and 1 1/4" if I use left or right ailerons. The problem is if I put the stick to one of the corners like full up elevator and full left aileron, I get more than the original 1 1/4" of travel and the servo arm cant move any further. I've tried setting the ATV's but it doesn't help. Any suggestions ??
Larry
