ORIGINAL: Harleyflyer
Does anyone know how the flight characteristics are between these two planes? I have a TT 46 that needs a home and I think one of these might be a good candidate.
Thanks.
I think I can help you out. Both would fly very well with that engine. I've used that engine myself many times. The Edge is designed to be the entry level 3D trainer although it has tremendous capability given full throws and the right thumbs. The Yak is the more advanced 40 size profile and is significantly looser and more agile. Both are built using my unique combination of fiberglass tubed fuse and balsa sheeted built up frame for a very tough and stiff arrangement. Both have the two piece wing setup as well which is much easier to build, much more durable than a single one piece glued in wing and of course much easier to repair should you dork the plane up. Hope this helps!
