RE: Gas Engine Throttle Linkage Setup
Depends on the design of the venturi and where the high speed jet is. All the smaller, 1" bore or less carbs I've seen have a cast venturi. There are some larger machined bore carbs. Most of the carbs have jets on the side and as the plate rotates past them it draws out the fuel.
The plate needs to be angled so a pressue vacume is formed to draw the fuel from the jets.
