RE: Sig Rascal 110
Zippi,
where are you going to mount the ignition battery and the ignition? i made a long slot down from the fuel tank hole almost to the bottom of the firewall and coated the spark plug wire with some small wire loom and then wrapped it really good with electrical tape.
did the address work for you?
your engine install looks great. now comes the fun part......mounting the cowling. i spent about 2-3 hour mounting the one on the blue and white rascal the other day. i think i pulled the cowling on and off about 20 times making small cuts here and there until i liked the way it fit.
keep up the good work. i think they may open up the field Saturday around 4 or 5 for open flying in case you want to bring it with you???
Eric
