RE: Sig Rascal 110
Eric,
Yes, the address worked fine. Thanks. I was thinking about cutting a vertical slot but I can't turn the spark plug wire up to get it to go through the firewall. The cap and wire stick down way to far. Cowlings are not one of my better things to be doing on an ARF but I'll just keep cutting away as you did. Since I put my rudder servo in the rear of the fuse I guess I'll need the battery and EI under the tank. Is that where yours is? Is there room? I wont be finished in time to bring it down and I still don't have my prop bolt and washer that Ralph forgot to send me and my Graphics have not came in yet.
