RCU Forums - View Single Post - YS-170CDI Flight Report
Old 10-17-2008 | 01:05 PM
  #102
mmattockx
Default RE: YS-170CDI Flight Report
ORIGINAL: Charley
It would mean more if we knew the 16x8 RPM with 5%.
CR
According to Pe Reiver's prop power calculator, which has proven to be quite accurate, a 16x8 prop is 30% more load than a 15x8 prop. Assuming the same brand and prop load factor... Add in the 200 rpm extra on the 16x8 and the engine was making around 39% more power on the high nitro mix than the 5%.
Mark
