RCU Forums - View Single Post - Avistar Select batter charging question
Old 05-27-2003 | 12:08 AM
midnitedew
Default Avistar Select batter charging question
Originally posted by mjd3
15 hours. It's specified in the Radio documentation.
Also, the battery that comes with that radio is 600 mAh, and the carger supplies 50mA. 600 / 50 + 25% = 15 hours.
thank you very much... now i epoxyed the wing and i decided to see if the ailerons were centered so i pluged in everything turned it on started moving the stick left to right.... when i move the aieleron stick to the extreme left then move it to center then move it about 25% to the right the wing makes a loud POP!
everything seems to work right on the plane ailerons seem to move ok... what is this annoying POP noise? can it be fixed? thank you...
