RCU Forums - View Single Post - Gas Engine Throttle Linkage Setup
Old 10-17-2008 | 02:28 PM
Tired Old Man
Default RE: Gas Engine Throttle Linkage Setup
If you cut the spring stop tabs off of some Tillotsen carbs you can go almost full circle with the throttle plate[X(] Most definately check that you are not doing so.
